13 years agoStratix II ES180 board, help me with DAC output
Hi all, I am in trouble with ADC module. I try to code a very simple code: module dac_test( input clk, output [13:0] dac ); assign dac = 14'b11110001010110; endmodule...
13 years agoI don't know the board itself but there is a mismatch between your code and your text. In you code, you are defining a parallel output for the DAC, using 14 signals, but in your text you are talking about a single pin, suggesting a serial output. If the DAC's input is a serial signal (which I suspect it is) then you need to do a parallel-to-serial conversion in your FPGA code.
