Stratix 10 does not power up
Hi Ankur
You need to refer to the quick started guide in the link below:
I believe the link above is of the same product with your card except that yours is of ES version.
If you already follow the quick started guide and still not able to bring up the card, from the description you mentioned, it seems to be hardware issue. You should contact the distributor from which you purchased the hardware for exact warranty information. You will need to file RMA as stated in the link below:
Eng Wei
- Akumar5 years ago
Hi Wei,
Our FPGA was bought from Mouser and we are out of the 90 days period.
Can we still get it repaired? Please let us know.
Thank you
Ankur- EngWei_O_Intel5 years ago
Hi Ankur
You shall contact Mouser for warranty related issue. They will be able to assist you.
Eng Wei
Hi Ankur
I got an update that the link provided previously has been outdated. We had issue a remove on the link. The Dev kit warranty coverage has extended from 90 days to 1 year.
Can you provide us the Dev kit serial number so I can check for you?
Eng Wei
