XWang21
7 years agoStratix 10 development board failed to load configuration
I am trying to load my design onto the Stratix 10 dev board. I use Quartus pro v17.1, as the chip model 1SG280LU3F50E3VGS1 is only supported in that version. In the Programmer, after auto detecting ...
YuanLi_S_Intel
7 years agoHi Xiaowei,
Yes, Red LED lights up after you have powered on your board indicates that the configuration is not done. Can you try to change the switches to default position and have msel select to JTAG config mode, then change the TCK frequency to 6MHz and program again?
YL
