AleCampla
6 years agoStratix 10 1G/2.5G Ethernet reconfiguration not working in hardware
i have ported the design of the 1G/2.5G Ethernet Design Example to the Stratix 10 MX.
I removed the loopback on the gmii side, the traffic controller and one of the two channels, as my design...
- 6 years ago
Hi dlim,
I finally managed to communicate with the PHY.
One problem was that some of the switches were not in the right position, so the pointer in the scripts was not pointing to the S10 FPGA.
Also a reset_n on the fw side was not negated (and so it was always in resetting all the time).
This is then solved.
A part for one register (for auto negotiation enabling) that I can't write.
But I would open a new ticket for that.
Thanks for your support.
Alessandra
Deshi_Intel
6 years agoHI,
Good. So you have found the issue to be the switch setting on board.
Alright, I am setting this case to closure.
dlim
