14 years ago[StartupKit_Xylo] USB program and FPGAConf
Hi eveyone, I use the Startup Kit for a Xylo FPGA Board EP1C3T100C8. I use the "FPGA Project - USB-2 (FX2) 1 - Blink leds" sample which allow you to blink LEDs via USB protocol... So I u...
14 years agoHi Daixiwen,
does fpgaconf might change usb interface during upload ? Because, I try another program which only blinks leds (without USB communication) and it works when I program it in the FGPA's SRAM (I use the button "Program Boot-PROM" of FPGAConf). So I can power off then power on my board and the program is still running :) But when I upload a program that use USB communication, it does not work... :( SO, I suppose there is something happening during the configuration of FPGA (button "Configure FPGA of FPGAConf) Yes, I have read the documentation that you can find here : http://www.knjn.com/docs/knjn%20fx2%20fpga%20boards.pdf Have you good an idea ? Thanks a lot !
