14 years ago[StartupKit_Xylo] USB program and FPGAConf
Hi eveyone, I use the Startup Kit for a Xylo FPGA Board EP1C3T100C8. I use the "FPGA Project - USB-2 (FX2) 1 - Blink leds" sample which allow you to blink LEDs via USB protocol... So I u...
14 years agoI don't know this kit, but the FPGAConf tool probably only uploads your design to the FGPA's SRAM, so you loose it when you turn the power off. What kin of configuration device is there on the board? Have a look in the documentation for a way to flash an FPGA configuration.
