Starting Arrow SoCkit CycloneV from QSPI problem
Thank you for responding!)
I used GHRD from the quartus folder, 'intelFPGA/18.1/embedded/examples/hardware',
and as a step-by-step instruction, I took the article from 'https://rocketboards.org/foswiki/Documentation/GSRD131QspiBoot'
Regardless of the choice in the bsp-editor BOOT_FROM_SDMMC or BOOT_FROM_QSPI
my build system ultimately refuses to start((
The only thing I can say is that if I use GHRD from the quartus 13.1 folder, and use quartus13.1 & socEDS13.1, then the boot is successful for me, but there I come across a partition markup problem, but this is already a secondary question.
Thus, I would like to understand how the assemblies are different in 13.1 / 18.1 and what needs to be changed in 18.1 in order to run successfully)
There have been a lot of changes since 13.1 to 18.1, thus I suggest that you tried to boot using the 18.1 GHRD at first. If there are any problems let me know.
Release notes for 18.1 can be here:
https://rocketboards.org/foswiki/Documentation/ReleaseNotesAndContentsLTS
