9 years agoSometimes can't program 10M80 Development Board
I have this strange error when I try to program the board. At work it works fine, but when I'm working from home I get a "209012 Operation failed" error. It's happening today and last week, but yeste...
9 years agoNow at work and tried again with the exact same .cdf files, and no problems programming. Same setup. Laptop on table without power connection, same two USB cables in same two USB ports, to same dev board USB micro ports. Same dev board power supply.
Could the dev board be very sensitive to temperature or humidity differences? The office has A/C, but the home office doesn't. Maybe if it has a poor solder joint or something?
