WOsca
7 years agosoldering open issue
Issue Des. : Currently we find parts(EP3C5F256C6N)have open issue after soldering process at the ICT test station in our production line.
Total input: 100 pcs
Failure QTY:44 pcs ( 43 pcs in 44 is manufactured in MALAYSIA, while the rest one is from Korea which we used before with no issue)
Failure rate: 44%
1. We have done 5D XRAY inspection with no findings regarding to the soldering condition, the soldering seems no obvious problem.
2. Reheat 5 pcs failure EP3C5F256C6N on board, retest the ICT with 1 pc test pass and 4 pcs still failed
3. Replace the NG EP3C5F256C6N(Malaysia) with a new EP3C5F256C6N(Korea), ITC test pass
1 Reply
- YuanLi_S_Intel
Hi WOsca,
I have received the enquiry. I will continue to support you via private message.
Thank You.
YL
