15 years agosof2flash error
I try to add my applicaiton into CycloneIII application selector. I need to convert .elf and .sof into _sw.flash and _hw.flash files. When I run eek.sh script I got error. I also run the command line and got the same error. The .elf to _sw.flash is converted succesfully. But .sof is not. The error messages is attached(EEK_SH.JPG). I am wondering it is because of license issue or because of something else. The first error read: QuartusII convert_programing_file was unsuccessful, but gives no reason. Please help. OnePlusOne2 Replies
If file names are correct (and I presume you already checked them...) then you have a problem with paths. Is the .sh file in the same location as .sof? If not, are the relative paths correct?
I'd suggest you open a shell session and send manually the sof2flash command. - Altera_Forum
I found a similiar lead for this problem. I think it is the licence issue. Thank you for your reply. OnePlusOne
