15 years agosof2flash error
Hi, I try to add my applicaiton into CycloneIII application selector. I need to convert .elf and .sof into _sw.flash and _hw.flash files. When I run eek.sh script I got error. I also run the comma...
15 years agoIf file names are correct (and I presume you already checked them...) then you have a problem with paths. Is the .sh file in the same location as .sof? If not, are the relative paths correct?
I'd suggest you open a shell session and send manually the sof2flash command.
