12 years agoSoCKit, U-Boot problem
Hi all, I just registered in order to post this new thread, because I have been looking for some information that could help me with this issue, but I'm not able to find anything useful. I...
12 years ago --- Quote Start --- I got this when the preloader wasn't able to find a valid u-boot. It turned out that I wasn't using the u-boot with the header applied. --- Quote End --- It seem to have a similar problem when I try to use a new version of u-boot. Which header files did you change? I assume you copied files from 'spl_bsp/generated' folder to 'board/altera/socfpga'. Is it correct? I would hope that default files would boot but I get this repeated over and over regardless which headers I use: U-Boot SPL 2013.01.01 (Jul 05 2014 - 19:15:46) BOARD : Altera SOCFPGA Cyclone V Board SDRAM: Initializing MMR registers SDRAM: Calibrating PHY SEQ.C: Preparing to start memory calibration SEQ.C: CALIBRATION PASSED ALTERA DWMMC: 0 reading u-boot.img reading u-boot.img The older u-boot, which comes with Quartus 13.1 works. Regards, Roman
