12 years agoSockIt System Console in Q-II v13.1
Hi, I'm just posting a problem that I found in trying to run the Arrow SoC Hardware Lab on the Sockit board in the hope of helping others avoid it. In Module 6: System Console, the test_o...
12 years ago --- Quote Start --- Hi, I'm just posting a problem that I found in trying to run the Arrow SoC Hardware Lab on the Sockit board in the hope of helping others avoid it. In Module 6: System Console, the test_one.tcl script works fine when run under Q-II v13.0, but fails under v13.1. I've traced this down to the address format in the tcl scripts. For example in test_one.tcl you may find a line: master_write_8 $jtag_master 0x1_0040 $val v13.1 of Q-II doesn't like the underscore in the address, so 0x1_0040 needs to be changed to 0x10040. All of the underscores in the addresses in the scripts appear to need to be removed. I hope this helps others. Cheers AL --- Quote End --- Thank you, I was struggling to run this example and I was stuck at the same problem. This kind of changing without warning is a bit annoying...
