SOC EDS for Quartus Prime 21.1 standard version
For generating sdcard image for customized cyclone 5 board, I'm using the Quartus Prime 21.1 Standard Edition, can you please help with which version of SOC EDS software to be used. Also, if you can share the user guide and design example for the same.
snehal_p
- sstrell
rocketboards.org is your friend. You can get an example design and customize it for your board/design.
- snehal_p
Contributor
Hello sstrell,
Thanks for your reply.
Can you please help with which version of SOC EDS software to be used for, Quartus Prime 21.1 Standard Edition.
snehal_p
- Jeet14
SoC EDS is a discontinued product, and no longer supported.
If you still want to use then you can try using the last release SoCEDS v20.1
Reference, https://www.rocketboards.org/foswiki/Documentation/SoCEDS
Tiwari
- snehal_p
Contributor
Hello Tiwari,
We are following the below document,Quartus Prime 22.1 Standard Edition.
We are getting below error while building uboot
/usr/bin/ld: tools/imagetool.o: in function `imagetool_get_type':
imagetool.c:(.text+0xa): undefined reference to `__stop_image_type'
/usr/bin/ld: imagetool.c:(.text+0x12): undefined reference to `__start_image_type'
/usr/bin/ld: tools/imagetool.o: in function `imagetool_verify_print_header':
imagetool.c:(.text+0x73): undefined reference to `__stop_image_type'
/usr/bin/ld: imagetool.c:(.text+0x7a): undefined reference to `__start_image_type'
collect2: error: ld returned 1 exit status
make[1]: *** [scripts/Makefile.host:104: tools/dumpimage] Error 1
make: *** [Makefile:1900: tools] Error 2Can you help with the above error
snehal_p
- Jeet14
Please let me know if you have any query on this.
Tiwari
- Jeet14
- KennyT_altera
reopening the case
- Jeet14
Are you getting these error in Quartus v22.1std or ARM DS?
Also, are you using the custom design or referring the GHRD?
Tiwari
- snehal_p
Contributor
I'm getting this error while generating uboot , with Quartus v22.1std, while using both the custom design or referring the GHRD.
snehal_p
- Jeet14
There is no issue at my side in compiling the uboot from the GHRD.
I hope you have gone through the required prerequisites and setup the proper tool chain before the uboot compiling.
Tiwari
- Jeet14
Hi
Let me know if you have any question on this.
Tiwari
