WabG
2 years agoSoC Cyclone V : FPGA full configuration from HPS FPGA Manager, MSEL issue ?
Dear support, We are using a SoC cyclone V and want to configure the FPGA portion from HPS through the FPGA manager. We have followed the procedure described in HPS Technical Reference Manual (cv_5...
aikeu
2 years agoHi WabG,
I not able to confirm about the particular MSEL thing. By default, simply booting up from qspi or sd card, we dont purposely do any changes to the MSEL settings, the FPGA configuration still can be loaded with quartus programmer or using FPGA load cmd in Uboot. I suggest working with the default working settings then only try to make the changes in order to see if that affects the FPGA configuration load operation.
Aik Eu
FvM
2 years agoHi,
FPGA Manager specification, Table 4.1 is pretty clear about this point, I believe. FPGA configuration from HPS is only supported for FPPx32 and FPPx16 MSEL setting.
- WabG2 years ago
This isn't so clear on the control register description of the FPGAManager : "Controls whether the FPGA configuration pins or HPS FPGA Manager drive configuration inputs to the CB."
https://www.intel.com/content/www/us/en/programmable/hps/cyclone-v/hps.html#sfo1410067797617.html
WabG
