16 years agoSlow frame rate (DE1 + D5M)
I connected the d5m camera to the de1 board and loaded the DE1_D5M project. When I plug the vga connector I can see images, but with a very slow rate. If I increase it (sw0 + key1) the image quickly ...
16 years agoi did not make any change in the code given with the camera, but the camera is not capturing the right images or the code is not able to display the image correctly. i am not sure if the camera is damaged or what...
the green LED's on the DE2 board blink with the rate the camera is capturing images, the output on the monitor is also blinking with the same pattern of random images. how can i chek the camera is working fine?
