Savino
1 year agoSimulating by ModelSIM signals multiple blocks nested inside each other on quartus||
good morning, in the quartus|| environment I inserted in a new schematic file, two blocks: an LPM Counter and an LPM compare and other signal like clock, ect. After that I created a new block contain...
- 1 year ago
Please follow the previous mentioned steps.
In work library, double click the main screenshot:
In object panel, you'll see those signals clk, clk_en, cnt_en, as_res, spi, out. Select all and right-click -> Add Wave screenshot:
Those signals will be added to wave panel screenshot:
Sheng
ShengN_altera
1 year agoHi,
In Project Navigator -> Files, all the .bdf need to be changed to HDL. Double click the .bdf -> File -> Create/Update -> Create HDL Design File from Current File.
Then include the HDL files (.v/.vhd) to Project Navigator and remove the .bdf from Project Navigator. Attached the design for your reference.
Sheng
