Simulating by ModelSIM signals multiple blocks nested inside each other on quartus||
- 1 year ago
Please follow the previous mentioned steps.
In work library, double click the main screenshot:
In object panel, you'll see those signals clk, clk_en, cnt_en, as_res, spi, out. Select all and right-click -> Add Wave screenshot:
Those signals will be added to wave panel screenshot:
Sheng
hi, I had already provide up the two file of the design. Below attached again. My goal is view and force some signals in simulation by means ModelSim, all signal in the project, like spi signal ecc because when i lunch ModelSim, in work folder i only can simulate and force the signals of the two megafunction block and not the other signal. It seems that it only needs blocks from the magafunction libraries to work. So how can i simulate nad force all signals in my design?
