Savino
1 year agoSimulating by ModelSIM signals multiple blocks nested inside each other on quartus||
good morning, in the quartus|| environment I inserted in a new schematic file, two blocks: an LPM Counter and an LPM compare and other signal like clock, ect. After that I created a new block contain...
- 1 year ago
Please follow the previous mentioned steps.
In work library, double click the main screenshot:
In object panel, you'll see those signals clk, clk_en, cnt_en, as_res, spi, out. Select all and right-click -> Add Wave screenshot:
Those signals will be added to wave panel screenshot:
Sheng
Savino
1 year agohi, i am a little bit confused. in order to simulate all the signals I need, do I have to convert the main file (which contains other blocks) into an HDL file? How do I do it?
Savino
1 year agoI converted the file in verilog HDL but when i lunch modelSIM, in work folder still i dont see all the entire signal i need
