Savino
1 year agoSimulating by ModelSIM on quartus|| 9.0 - XOR function bus_signals error in verilog file
Good evening everyone, for several hours I have been running into a problem using quartus|| 9.0 and ModelSim. I have created a very simple project with a bus input and a bus output, and an XOR funct...
- 1 year ago
Hi Savino,
I misunderstood the situation. As mentioned by sstrell, the input must be same width. Using same width will be no problem.
You're using different width, that's why causing the bug.
Sheng
ShengN_altera
1 year agoHi,
Please change this assign out = in[29:0] ^ {in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in,in}[30]; to this assign out = in[29:0] ^ in[30];
Sheng
- Savino1 year ago
Hi, I tried all the combination without succes and at the end i used more xor gate for each single data, like attached and i fixed the issue but if is possible do the xor operation in one shot for me is better (like at beginning working with bus data)
