PJais1
6 years agoSimple Socket Server link established(SGMII) but cannot telnet/ping
Hello , I am using a Arria 10 Custom Board, and testing ethernet which is in SGMII mode. I have used a development kit reference design and changed the FPGA(10as066k2f40e1hg). After building the d...
Deshi_Intel
6 years agoHi,
Simple socket server template and reference design is typically used as it's reference design with min support.
It involved more on system level design which is not easy to debug.
However, if you are able to isolate the issue until TSE IP level then I may be able to help you out further.
- For instance, can you duplicate issue using TSE IP only to isolate first is this data link or physical layer issue or network layer issue ?
- Or do you see the data packet flow broken in somewhere ? NIOS -> DMA ? -> TSE -> PHY ?
dlim
