Shift Register to RAM inference
I'm wondering what would be the requirements for the compiler to be able to infer shift registers to ram?. I instanced the template from quartus template but this is using FF instead of ram memory. My FPGA is 10CL080YF780I7G:
-- Quartus Prime VHDL Template
-- Basic Shift Register with Multiple Taps
library ieee;
use ieee.std_logic_1164.all;
entity basic_shift_register_with_multiple_taps is
generic
DATA_WIDTH : natural := 8;
NUM_STAGES : natural := 56
port
clk : in std_logic;
enable : in std_logic;
sr_in : in std_logic_vector((DATA_WIDTH-1) downto 0);
sr_out : out std_logic_vector((DATA_WIDTH-1) downto 0)
--srvector : out std_logic_vector(NUM_STAGES*DATA_WIDTH-1 downto 0)
end basic_shift_register_with_multiple_taps;
architecture rtl of basic_shift_register_with_multiple_taps is
-- Build a 2-D array type for the shift register
subtype sr_width is std_logic_vector((DATA_WIDTH-1) downto 0);
type sr_length is array ((NUM_STAGES-1) downto 0) of sr_width;
-- Declare the shift register signal
signal sr: sr_length;
begin
process (clk)
begin
if (rising_edge(clk)) then
--if (enable = '1') then
-- Shift data by one stage; data from last stage is lost
sr((NUM_STAGES-1) downto 1) <= sr((NUM_STAGES-2) downto 0);
-- Load new data into the first stage
sr(0) <= sr_in;
--end if;
end if;
end process;
end rtl;
