SKon1
6 years agoSetting output delay
Hello, I want to constrain my system (attached) for input and output delays. The input delay is straightforward. But I have my doubts about the output delay. This is what I did for the input delay...
sstrell
6 years agoYes, that looks good. Your max and min values should of course be based on the timing requirements of the "downstream" device that you are connecting to, and usually those values (or at least not both of them) aren't negative. Do you have setup/hold info or skew info for the downstream device?
#iwork4intel
