17 years agoSend on a 8 data bus : 8 data and 8 data and ...
My problem is very simple : I want to send on a single bus of 8 bits (named "BigBus" for example), 3 differents letter (coded in ASCII so 8 bits each). At each clock count, the data must change : BigBus = Letter 1 (Wait rising_edge clock) Letter 2 (wait rising_edge clock) Letter 3 (Wait rising_edge clock) Letter 1 (Wait rising_edge clock) Letter 2 ... I know that what I shearch is a multiplexer but every example I have are not easy to write in vhdl and furthermore, I want to add a new letter quickly (in fact, if it's possible, I just want to add a line for each letter added). Thanks for your help and sorry pour my bad english, I'm French...:rolleyes:2 Replies
use counter and case, or 2D array:
type my_data is array(0 to 2) of std_logic_vector(7 downto 0); signal my_characters: my_data := ("01110100","00001111","00110000"); -- or --constant my_characters: my_data := ("01110100","00001111","00110000"); signal count: integer range 0 to 2; begin process begin wait until clk = '1'; if count = 2 then count <= 0; else count <= count + 1; end if; bigbus <= my_characters(count); end process; - Altera_Forum
ok, thanks :)
I test and I confirm if everything is alright
