MHafi3
6 years agoSend data from FPGA to pc.
Hi, I'm currently using De10 lite FPGA interfacing with 16-bit ADC to take voltage measurement. After some processing the output would be 32 bits and i would send it to pc and view it on labview. Is ...
ShafiqY_Intel
6 years agoHi MHafi3,
You need to instantiate the UART IP in your design. You may refer to below reference design to see how we implement UART in our design:
- https://fpgacloud.intel.com/devstore/platform/16.0.0/Standard/max10-remote-system-upgrade-rsu-over-uart-for-nios-ii-processor/
- https://fpgacloud.intel.com/devstore/platform/15.1.0/Standard/remote-system-upgrade-over-uart-based-on-nios-ii-processor-with-epcq/
Let me know if you need further clarification.
MHafi3
6 years agoHi ShafiqY_Intel ,
Thank you for replying.
Currently im able to display data from my vhdl code to NIOS 2 processor by instantiate PIO and JTAG UART and view it on nios2 terminal through stdout command. Is there any method that i can use to transfer the data to labview via serial ?. My DE10-lite board only have JTAG_UART interface to connect to the host pc.
