8 years agoSDRAM rzqin pin on Arria V starter kit
Hello Alteraforums I'm trying to get the SDRAM on my Arria V starter kit working. I have set up the module in my qsys design, and have exported the appropriate conduits. There is an input ...
8 years agoUsing a reference design, I determined that PIN_E32 should be the right one
I try to compile, but when the fitter runs, I get 1400 errors! here's some examples:
Error (174068): Output buffer atom "nios_system:inst2|nios_system_sdram:sdram|nios_system_sdram_p0:p0|nios_system_sdram_p0_memphy:umemphy|nios_system_sdram_p0_new_io_pads:uio_pads|nios_system_sdram_p0_altdqdqs:dq_ddio.ubidir_dq_dqs|altdq_dqs2_acv_arriav:altdq_dqs2_inst|extra_output_pad_gen.obuf_1" has port "SERIESTERMINATIONCONTROL" connected, but does not use calibrated on-chip termination
Error (174068): Output buffer atom "nios_system:inst2|nios_system_sdram:sdram|nios_system_sdram_p0:p0|nios_system_sdram_p0_memphy:umemphy|nios_system_sdram_p0_new_io_pads:uio_pads|nios_system_sdram_p0_altdqdqs:dq_ddio.ubidir_dq_dqs|altdq_dqs2_acv_arriav:altdq_dqs2_inst|extra_output_pad_gen.obuf_1" has port "PARALLELTERMINATIONCONTROL" connected, but does not use calibrated on-chip termination
Error (174068): Output buffer atom "nios_system:inst2|nios_system_sdram:sdram|nios_system_sdram_p0:p0|nios_system_sdram_p0_memphy:umemphy|nios_system_sdram_p0_new_io_pads:uio_pads|nios_system_sdram_p0_altdqdqs:dq_ddio.ubidir_dq_dqs|altdq_dqs2_acv_arriav:altdq_dqs2_inst|pad_gen.data_out" has port "SERIESTERMINATIONCONTROL" connected, but does not use calibrated on-chip termination
Error (174068): Output buffer atom "nios_system:inst2|nios_system_sdram:sdram|nios_system_sdram_p0:p0|nios_system_sdram_p0_memphy:umemphy|nios_system_sdram_p0_new_io_pads:uio_pads|nios_system_sdram_p0_altdqdqs:dq_ddio.ubidir_dq_dqs|altdq_dqs2_acv_arriav:altdq_dqs2_inst|pad_gen.data_out" has port "PARALLELTERMINATIONCONTROL" connected, but does not use calibrated on-chip termination
Error (174052): I/O "SDRAM_DQ" has dynamic termination control connected, but does not use parallel termination
