12 years agoSDI Megacore on Stratix4 GX devkit. Mismatch pinnames in UG with actual device.
Hi, I'm trying to follow the SDI core on an S4 GX dev kit board. See also: http://www.altera.com/literature/ug/ug_sdi_ii.pdf Altera provide an example design S4GXSDI_AUDIO_TOP In th...
12 years agoHi Kimberly,
I rarely use the example designs as the "golden" reference for a kit, I always use the schematic (or at least confirm each pin in the golden reference with the schematic). I've attached my pin constraints file. Here's the SDI section from that file:
# Video out clock control (p6,9 )
set pin(sdi_clk148_up) {PIN = AH12, IOSTD = "2.5 V", DRIVE = 12mA, SLEW = 0}
set pin(sdi_clk148_dn) {PIN = AH11, IOSTD = "2.5 V", DRIVE = 12mA, SLEW = 0}
# Video out control
set pin(sdi_tx_sd_hdN) {PIN = V29, IOSTD = "2.5 V", DRIVE = 12mA, SLEW = 0}
# Video out
set pin(sdi_tx) {PIN = K4, IOSTD = "1.4-V PCML"}
set pin(sdi_tx(n)) {PIN = K3}
# Video in
set pin(sdi_rx) {PIN = L2, IOSTD = "1.4-V PCML"}
set pin(sdi_rx(n)) {PIN = L1}
--- Quote Start --- Can I just use the PIN_L2 instead of PIN_99? --- Quote End --- Yes, pin 99 is wrong, pin L2 is correct. Cheers, Dave
