13 years ago
S4GX530 dev kit; HDMI audio not working
Hi All,
I am using the AD9889B chip on the Startix 4 GX 530 dev kit. I am trying to get the audio up and running but unfortunately without any success.
Setup:
I have a 480p video test pattern output (running on a 27MHz pixel clock). The HDMI video is working fine.
For the audio : 48kHz Stereo, SCLK=3.072MHz, LRCLK=48kHz, MCLK=12.288MHz.
(I create these clocks with a PLL in the FPGA from the 27MHz video clock, so an integer relationship exists)
I pad the 16 bit audio data with zeroes to form 32 bit words. The 16 bit audio data that I would like to hear is a saw-tooth of about 100 Hz.
I set the following registers :
wr 0x96 <- 0x00 --clear interupts
wr 0x41 <- 0x50 --power down chip
rd 0x42 -> 0xE0
wr 0x17 <- 0x18 --csc
wr 0x3b <- 0x01 --enable csc
wr 0x15 <- 0x20 --48kHz audio; YCbCr 4:4:4 input
wr 0x16 <- 0x01 --output = YCbCr
wr 0x0C <- 0x04 --enable I2S(0), I2S format=standard (I am using 32bit per sample here, 2x32 for 1 stereo sample)
wr 0x50 <- 0x20 --enable 2 audio channels
wr 0x14 <- 0x02 --16 bit word length
wr 0x0A <- 0x01 --select I2S, Mclk inactive, Mclk ratio : 256xFs
wr 0x40 <- 0xF8 --
wr 0x44 <- 0x78
wr 0x45 <- 0x80 --AV mute disable, output format RGB
wr 0x94 <- 0xF0 --
wr 0x95 <- 0x00 --
wr 0x96 <- 0x40 --
wr 0x97 <- 0x00 --
wr 0x98 <- 0x07 --
wr 0x9C <- 0x38 --
wr 0x9D <- 0x60 --
wr 0xBB <- 0xFF --
wr 0x01 <- 0x00 --N = 6144
wr 0x02 <- 0x18
wr 0x03 <- 0x00
wr 0xAF<- 0x16 --HDMI mode
wr 0x41 <- 0x10 --power up chip
I have been checking and re-checking my register settings + general setup but can not figure out where I am going wrong.
Could anybody please help?
In Advance thx for your help
1 Reply
    Hi Nik83,
    For some reason I can not reply to your PM.
    So here is my reply
    Hi Nik83,
    I do not have a SOPC-system. I just made a little testproject where I generate a video source in VHDL + a I2C connection towards the AD9889B.
    Jan
