Ankit_P_Intel
6 years agoS10-DX-Kit PCIe driver failure
Hi All I have s10 DX kit and I am attempting to validate PCIe.sof file which SW package comes with. I loaded sof file in the kit and device is visible in 'lspci' command. (there was one device wit...
BoonT_Intel
6 years agoHi Sir,
I am not aware about any pre-compile sof that came with SW package. By right, you should generate the example design using quartus (as mentioned by the User Guide), then compile the design to generate the SOF.
To make the DMA run successfully, you should not use Quartus 19.4. Seem like the issue that you are facing is matching with this KDB.
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/ip/2020/why-does-the-data-transfer-test-is-hang-when-running-intel--fpga.html
Boon Chiek
