NAdel1
6 years agoRSU, Factory and application in CyclonV
I have factory image and application image and it works properly. When the application image corrupt at the beginning the "pof_error" signal is high. but.... When the application image is corrupt i...
YuanLi_S_Intel
6 years agoHI Naftali,
Usually, when appliaction image is having issue, the RSU will try to reload the application image 2/3 times. After that, it will fall back to factory image.
What you are seeing is normal, the bit 0 is 1 as your RSU fails to load application image. It will turn to 0 (normal) when factory image is loaded.
Thank You
