SLabe
6 years agoromstyle="MLAB" attribute is ignored
Looking how to infer a small ROM into MLAB. When using the following code, the resulting altsyncram still reports RAM_BLOCK_TYPE set to AUTO instead of MLAB. I use the following code, tries romstyle ...
KhaiChein_Y_Intel
6 years agoHi,
I can duplicate the error, the ROM type is set to AUTO even the romstyle="MLAB" attribute is used. I tried to set the romstyle to "M10K", the ROM type is set to M10K in the Fitter report under RAM Summary, which is the correct behavior. I think this is the error on MLAB setting only. I will file a case to engineering for this error. Thanks for reporting this to us. Coud you use the IP Catalog to instantiate ROM with MLAB type as a temporary workaround?
KhaiY
