SLabe
6 years agoromstyle="MLAB" attribute is ignored
Looking how to infer a small ROM into MLAB. When using the following code, the resulting altsyncram still reports RAM_BLOCK_TYPE set to AUTO instead of MLAB. I use the following code, tries romstyle ...
KhaiChein_Y_Intel
6 years agoHi,
May I know what device you are using? It would be great if you could provide the QAR archive file as it contains all the settings same as your design file. To generate the archive file, click on Project > Archive Project
KhaiY
