romstyle="MLAB" attribute is ignored
Hello KhaiY,
I'm using Quartus Standard 18.0 for Windows. Here is my full code snipet if you wish to reproduce. Three scenarios:
- Code as is, all settings default, it results in the ROM being implemented with one M10K.
- romstyle removed, all settings default, it results in the ROM being implemented generic logic due to its small size. (Uninfered RAM logic)
- romstyle removed, "allow rom size recognition: on", it results int the ROM being implemented with one M10K
Example Code:
module ROM_init
#(parameter DATA_WIDTH=8, ADDR_WIDTH=5)
input clk_50,
input [(ADDR_WIDTH-1):0] addr,
output [(DATA_WIDTH-1):0] q_o,
output [(DATA_WIDTH-1):0] p
// ROM Test
// Quartus Prime Verilog Template
// Single Port ROM
assign q_o = q;
// Declare the ROM variable
reg [(DATA_WIDTH-1):0] q;
(* romstyle="mlab"*) reg [DATA_WIDTH-1:0] rom[2**ADDR_WIDTH-1:0];
reg [(ADDR_WIDTH-1):0] addr_reg;
initial
begin
$readmemb("baseline.txt", rom);
end
always @ (posedge clk_50)
begin
addr_reg <= addr;
q <= rom[addr_reg];
end
// IP Catalog version for comparisson
//rom1port rom1port_inst (
//.address ( addr ),
//.clock ( clk_50 ),
//.q ( p )
endmodule
// For reference baseline.txt is as follow:
00000000
00000001
00000010
00000011
00000100
00000101
00000110
00000000
00000000
00001000
00010000
00100000
01000000
10000001
10000010
00000000
00000001
00000010
00000011
00000100
00000101
00000110
00001000
00010000
00100000
01000000
10000001
00001000
00010000
00001000
