Tahir's avatar
Tahir
5 years ago
RMS and POWER calculation with MAX10 with two 14bit parallel ADCs
Can I use MAX10 to capture two 14bit ADCs for voltage and current at 7MHz sampling rate to calculate RMS and Power from the voltage and current? Will it be enough to do the operations or do I need a better FPGA?
    • Tahir's avatar
      Tahir
      How can I receive 7MSPS the ADC is just 1MSPS?
      It is not possible to use the ADC, it is very slow just 1MSPS.
      • EngWei_O_Intel's avatar
        EngWei_O_Intel
        Hi Tahir
        This is the ADC maximum speed available for Max10 devices. If you need higher sampling rate, you might need an external ADC.
        Eng Wei
