11 years ago
Resetting the board
Hai,
I am using Altera Cyclone V board https://www.altera.com/products/boards_and_kits/dev-kits/altera/kit-cyclone-v-soc.html
I used the preloader generated by bsp-editor, programmed the same using HPS software to QSPI flash memory.
Next to preloader I programmed the baremetal-application(LED blinking program). I programmed the same using HPS software to QSPI flash memory.
After power-on reset, the execution of program is perfect, First the preloader executes and then my program executes..
But When I press, the reset buttons in the board, there is no response.
1. When i press warm and cold reset button, the controller is hanged.
2. When I press cpu reset button, there is no response.
Could any one please help me to solve the issue..
    look, i caught by this issue before, it was some bug with the board reset mechanism that causing the system failed to boot in qspi mode!
    --- Quote Start ---
    --- Quote End ---
    And how did you solve it? Or what did you do a out it?
    x
    fastest way is use QSPI Flash Part which is < 16MB capacity.
