RESERVED_INPUT_WITH_WEAK_PULLUP pins in DE1- Lite
- 1 year ago
according to DE10-Lite schematic, all GPIO connector pins are connected to RX/TX capable pins in 3.3V IO banks, also questioned GPIO_7 and GPIO_9. I presume, you are seeing "RESERVED_INPUT_WITH_WEAK_PULLUP" in the .pin file of a specific project. It reflects the pin assignments of the design, not the capabilities of the FPGA. "Reserved input" is the assignment of an unused pin. You need to assign intended pins to top level signals in Pin Planner tool or Assignment Editor.
