Michelle4
1 year agoReplacement part number for EP20K200RI240-2
I am looking for the replacement part number for Altera part number EP20K200RI240-2. The EOL says that it is Cyclone Series FPGAs but does not give a part number.
FakhrulA_altera
1 year agoHi Michelle4,
As the fellow member mentioned, there is no direct, pin-compatible replacement for the EP20K200RI240-2. Newer Intel/Altera FPGAs like the Cyclone IV or Cyclone 10 series are suggested for migration, but they come in different packages and require changes to your PCB and possibly your power supply.
In summary, you'll need to redesign your board and port your code to use a modern Cyclone FPGA. If you share your requirements, we can help recommend the best device for your needs.
Fakhrul
