SMS
7 years agoRepetitive programming when using .pof file
Whenever I try to program the target device using a .pof file the Quartus programmer programs it in never ending loop unless stopped. I have tried using two different devices (i.e. 10M16SAE144I7G and...
ShafiqY_Intel
7 years agoHi SMS,
- May I know how do you convert your .pof file? which flash device you are using? (it would be great if you could share screenshot on how you set setting when convert to pof file)
- Did you use any IP Base Suite in your design?
