Maitry
1 year agoRegarding Ethernet /Transceiver tool kit error in F tile 10G Hard IP for AGFB027R24C FPGA device
Hello support team, We are using AGFB027R24C2I3E Agilex F series FPGA in our custom board. With Bank 13 A, 156.25 MHz (i_refclk2pll_clk) clock is interfaced ( CH6 = CJ7, CH8). And Tx, Rx is in CH1....
paveetirrasrie_Altera
1 year agoHi,
Good day to you.
May I know if the reset signals have been deasserted or not? This is because rx_pcs_ready deasserts when i_rx_rst_n/i_rst_n signal asserts or during the auto-negotiation and link training operation.
And also I would suggest you to try to generate design example using board type = Agilex devkit and compare the pin assignments to ensure the pin connections is same as devkit.
Pavee
