13 years agoReference Design, What should I do with DNI component??
I trying to design a board using the reference design of ALTERA cyclone V, I found many DNI components (resistors and capacitor), what i have to do with this components?, opened circuit? In the LP...
13 years agoHi Akael:
DNI stands for Do Not Install: These components may have been placed on the schematic for many reasons. IE your DQ lines are probably because one version of the schematic only supported a 16 bit memory, while another supports the full 32 bit interface. The CK and CK# resistor is probably for termination. If you are confident you know what the resistor position is there, you can safely remove them from your schematic. Pete
