Hi El,
this is linux booting info:
NAND read: device 0 offset 0x180000, size 0x80000
524288 bytes read: OK
## Starting application at 0x3FF5A5A4 ...
## Application terminated, rc = 0x0
## Flattened Device Tree blob at 00a00000
Booting using the fdt blob at 0x00a00000
Loading Device Tree to 03ff7000, end 03fffe5d ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.73-ltsi (root@localhost.localdomain) (gcc version 4.9.4 20151028 (prerelease) (Linaro GCC 4.9-2016.02)) #16 SMP Sun Feb 16 23:03:21 CST 2020
[ 0.000000] CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Altera SOCFPGA Cyclone V
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] percpu: Embedded 44 pages/cpu @ddbcd000 s150720 r8192 d21312 u180224
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 121920
[ 0.000000] Kernel command line: console=ttyS0,115200 root=/dev/mtdblock6 rw rootfstype=jffs2 init=/init mem=480M log_buf_len=1048576
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 472776K/491520K available (8192K kernel code, 532K rwdata, 1628K rodata, 1024K init, 1158K bss, 18744K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xde800000 - 0xff800000 ( 528 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xde000000 ( 480 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0900000 (9184 kB)
[ 0.000000] .init : 0xc0c00000 - 0xc0d00000 (1024 kB)
[ 0.000000] .data : 0xc0d00000 - 0xc0d85358 ( 533 kB)
[ 0.000000] .bss : 0xc0d8ba3c - 0xc0ead4d0 (1159 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] ftrace: allocating 26827 entries in 79 pages
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU event tracing is enabled.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] L2C-310 erratum 769419 enabled
[ 0.000000] L2C-310 enabling early BRESP for Cortex-A9
[ 0.000000] L2C-310 full line of zeros enabled for Cortex-A9
[ 0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
[ 0.000000] L2C-310 cache controller enabled, 8 ways, 512 kB
[ 0.000000] L2C-310: CACHE_ID 0x410030c9, AUX_CTRL 0x46060001
[ 0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604467 ns
[ 0.000006] sched_clock: 32 bits at 100MHz, resolution 10ns, wraps every 21474836475ns
[ 0.000019] Switching to timer-based delay loop, resolution 10ns
[ 0.000247] GIC: PPI13 is secure or misconfigured
[ 0.000280] GIC: PPI13 is secure or misconfigured
[ 0.000442] Console: colour dummy device 80x30
[ 0.000469] Calibrating delay loop (skipped), value calculated using timer frequency.. 200.00 BogoMIPS (lpj=1000000)
[ 0.000484] pid_max: default: 32768 minimum: 301
[ 0.000603] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000614] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001141] CPU: Testing write buffer coherency: ok
[ 0.001361] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.001660] Setting up static identity map for 0x100000 - 0x100060
[ 0.001779] Hierarchical SRCU implementation.
[ 0.002273] smp: Bringing up secondary CPUs ...
[ 0.002692] smp: Brought up 1 node, 1 CPU
[ 0.002705] SMP: Total of 1 processors activated (200.00 BogoMIPS).
[ 0.002713] CPU: All CPU(s) started in SVC mode.
[ 0.003474] devtmpfs: initialized
[ 0.008026] random: get_random_u32 called from bucket_table_alloc+0xfc/0x250 with crng_init=0
[ 0.008300] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 0.008502] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.008521] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.857848] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xdc
[ 0.864180] nand: Micron MT29F4G08ABADAWP
[ 0.868223] nand: 512 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[ 0.877649] Bad block table found at page 262080, version 0x01
[ 0.884655] Bad block table found at page 262016, version 0x01
[ 0.891826] 8 ofpart partitions found on MTD device denali-nand
[ 0.897748] Creating 8 MTD partitions on "denali-nand":
[ 0.902956] 0x000000000000-0x000000080000 : "NAND Flash Boot Area 512KB"
[ 0.910558] 0x000000080000-0x000000100000 : "NAND Flash u-boot 512KB"
[ 0.918177] 0x000000100000-0x000000180000 : "NAND Flash u-boot parameters 512KB"
[ 0.926673] 0x000000180000-0x000000200000 : "NAND Flash FDT 512 KB"
[ 0.933932] 0x000000200000-0x000000e00000 : "NAND Flash fpga config rbf file 12 MB"
[ 0.942726] 0x000000e00000-0x000001400000 : "NAND Flash kernel 6 MB"
[ 0.950306] 0x000001400000-0x000011400000 : "NAND Flash ubi rootfs 224 MB"
[ 0.959677] 0x000011400000-0x000011e00000 : "NAND Flash baremetal image 10 MB"
[ 0.968323] cadence-qspi ff705000.flash: couldn't determine fifo-depth
[ 0.974830] cadence-qspi ff705000.flash: Cannot get mandatory OF data.
