nhadzic's avatar
nhadzic
22 days ago
Proper PERST# connection for FMC on Agilex5 Modular Development Kit
I am using an Agilex5 Modular Development Kit to implement a design that has two PCIe endpoints. Each endpoint would run at the same x4 configuration (start with Gen3 and maybe move to Gen4). The fir...
  • AqidAyman_Altera's avatar
    AqidAyman_Altera
    17 days ago
    Whether the production Modular Development Kit already has PERST# physically routed from the PCIe edge connector to one of those HVIO pins, or whether you need a board-level modification, is a question specific to that board's schematic. I'd recommend checking the production board schematic (available from the kit webpage) to confirm whether that trace is already present before reaching for a soldering iron. If the board is used in PCIe slot mode, the nPERST line from the slot should reach the board; if it's used in tabletop/standalone mode, you may need to drive that pin from another source (e.g., an on-board logic signal or manual connection).
