JFrye2
6 years agoFirstly, should that FPGA programming message come up with the default version of uboot on github right now? Does the bsp-create-settings command grab the rbf and build it into u-boot with commands to program the FPGA or does this need to be added manually?
How do you partition and pack your files on to the SD card? Do you need to point u-boot to your script or will it begin running it automatically?
I was using this script https://raw.githubusercontent.com/rsarwar87/altera-soc-rootfs/master/make_sdimage2.py to simplify the partitioning/formatting process. This script will only let you make 4 partitions it seems each with only one file per partition. Is there a way to combine the u-boot-with-spl.sfp with the uboot.scr into one binary?
