Dt493
1 year agoPLD device EPM7032TC44
Hello 1.Kindly provide the programming manual for the device EPM7032TC44 . 2.The Device has 2 OE pins to communicate with I/O ports , does the device need both of them to be enabled or only one .Ki...
_AK6DN_
1 year agoSomething is not quite right here. You keep referring to your devices as 'EPM7032TC44' but this is NOT a jtag programmable device.
7032S, 7032A, 7032B all have JTAG programmable functionality and will return device codes 070320DD/170320DD/270320DD
respectively.
So how do you read the device code at get the value 414CC04B? What hardware do you use to read that device code?
What software are you using? Is it QuartusII 13.0sp1?
What is the EXACT part marking on your chip? Is it EPM7032, EPM7032S, EPM7032A, or EPM7032B?
