TRAN_HIEU_007
5 years agoNew port Ethernet use Cyclone10GX KIT error.
I add a new port Ethernet 1G in Cyclone10GX KIT. But I received this error.:
Error(14566): The Fitter cannot place 1 periphery component(s) due to conflicts with existing constraints (1 LVDS_CHANNEL(...
TRAN_HIEU_007
5 years agoHi Eng Wei. Currently I still fail with this project. I have tried many solutions including test loopback on Module FMC_Loopback using Transceiver toolkit and have been successful. But when transmitting through the SFP port, there is an error. Can you point out what is the correct I/O configuration for the TXP and RXP pins? I don't know if you have tried the 1G baseX transmission test project using the Cyclone10Gx chip yet? Thank you very much!
