OlegT's avatar
OlegT
5 years ago
MSI with avalonMM-DMA ip
Hello. I use pcie HIP with avalon-mm-dma interface, as an endpoint. Cyclone10GX evaluation kit. I need to send custom MSI to root complex (ubuntu PC). rxm_irq signals are not available due to mm-d...
  • Hi,
    I could not find the part that you have mentioned in the document. May I know which document you are referring to?
    According to the PCI Local Bus Specification 2.3,
    "If the Multiple Message Enable field (bits 6-4 of the Message Control register) is non-zero, the device is permitted to modify the low order bits of the message data to generate multiple messages."
    KhaiY
