Link status on BD-NVV-N3000-3 card
- 5 years ago
Thanks for your update on your debug status. Im glad to know that we have ruled out the cable or card issue. For the switch related queries, I am not the subject matter expert. Could you file a separate forum thread on the Ethernet products Forum (https://community.intel.com/t5/Ethernet-Products/bd-p/ethernet-products). They will be able to guide you from there. Appreciate if you can put in the link to the new thread for the benefit of others who face similar issue.
1) Thanks. I think you have answered me.
OPN refers to BD-NVV-N3000-3
Version loaded refers to the MAX10 build/NIOS version + Bitstream ID.
2) Yes, loopback module as shown in the link you referred: https://www.intel.com/content/www/us/en/programmable/documentation/zsf1588015530773.html#xzd1588094394268
No, it is not included in the package. You will have to purchase it separately from the module makers.
If you do not have a loopback module at hand, you can order for 2 (one for each cage). It will be useful for future debugging as well. Meanwhile, you can try connect the ethernet cable from QSFP cage A to cage B, and check fpgainfo phy. If port is up, then it would be the connection to the external switch issue. If it is still down, it would either be a card or a cable issue. To rule out if it is a cable issue, you will definitely need a loopback module.
Thanks! We just checked the port status by connecting two cages using an Ethernet cable, but
"fpgainfo phy" command still shows they are down:
Board Management Controller, MAX10 NIOS FW version D.2.1.24 Board Management Controller, MAX10 Build version D.2.0.7 //****** PHY ******// Object Id : 0xEC00000 PCIe s:b:d.f : 0000:08:00.0 Device Id : 0x0b30 Numa Node : 0 Ports Num : 01 Bitstream Id : 0x23000110010310 Bitstream Version : 0.2.3 Pr Interface Id : f3c99413-5081-4aad-bced-07eb84a6d0bb //****** PHY GROUP 0 ******// Direction : Line side Speed : 25 Gbps Number of PHYs : 4 //****** PHY GROUP 1 ******// Direction : Host side Speed : 40 Gbps Number of PHYs : 4 //****** Intel C827 Retimer ******// Port0 25G : Down Port1 25G : Down Port2 25G : Down Port3 25G : Down Retimer A Version : 101c.1064 Retimer B Version : 0000.0000
I suspect this is a cable issue because all four cards in our testbed show the same symptom. Is there a particular spec for a QSFP cable that is compatible with this card?
By the way, if I understand correctly, the default mode of BD-NVV-N3000-3 is 4x25GbE, where only one of the QSFP cage (i.e., cage A) is active. In this case, when we connect the Ethernet cable from QSFP cage A to cage B, do you still expect that the ports are up if there's no cable or card issue?
Regarding the loopback module, would the one in the following link work for this card?:
Daehyeok
- JonWay_altera5 years ago
For validated cable, please refer to datasheet: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ds/ds-pac-n3000-n.pdf (Table 2)
Yes, default user image is 4x25G. You need to switch to Factory Boot page for the 2x2x25G image. Then you can test with cable from cageA to cageB.
To switch to Factory Boot page (2x2x25G), run "rsu fpga -f"
- Daehyeok_Kim5 years ago
Thanks for your reply!
I switched the card configuration to 2x2x25G, tested it with cable from Cage A to Cage B, and checked that the port status is up:
[root@h12 daehyeok]# fpgainfo phy Board Management Controller, MAX10 NIOS FW version D.2.1.24 Board Management Controller, MAX10 Build version D.2.0.7 //****** PHY ******// Object Id : 0xF100000 PCIe s:b:d.f : 0000:08:00.0 Device Id : 0x0b30 Numa Node : 0 Ports Num : 01 Bitstream Id : 0x23000410010310 Bitstream Version : 0.2.3 Pr Interface Id : a5d72a3c-c8b0-4939-912c-f715e5dc10ca //****** PHY GROUP 0 ******// Direction : Line side Speed : 25 Gbps Number of PHYs : 4 //****** PHY GROUP 1 ******// Direction : Host side Speed : 40 Gbps Number of PHYs : 4 //****** Intel C827 Retimer ******// Port0 25G : Up Port1 25G : Up Port2 25G : Up Port3 25G : Up Retimer A Version : 101c.1064 Retimer B Version : 101c.1064With this, I've confirmed that there's no issue with the cable and card.
Since even in 2x2x25G mode, it still didn't work when I connected the card with the switch, I suspect there might be some issue with the configuration on the switch side. When I configured the switch port connected to the card, I set the rate to 25G and the FEC mode to RS for each lane (I checked the card is configured to use RS).
Could you advise what else should I check on the switch side?
Daehyeok
