SERMASWATHIKA
Contributor
2 years agoFW_CODE_NOT_WORKING_WHEN_CONFIGURED_FPGA_WITH_JIC_PROGRAMMING
Hi Team, We tried to check the jic file programming setup in Cyclone v gt eval board. For that we have created the system in FPGA design like this: nios ii reset and exception vector param...
SERMASWATHIKA
Contributor
2 years agoHi,
i have created new bsp and generated hex file. with that also address is not reflecting..
EBERLAZARE_I_Intel
2 years agoHi,
Which Quartus version are you using? Is the Cyclone V GT custom or the dev kit version?
Can you archive the Quartus design to me here? You are using the Hello World template in the Nios II SBT right?
I will help you check and create the .jic on my side.
- SERMASWATHIKA2 years ago
Contributor
We are using 22.1 quartus version and currently we are checking the design in starter vino kit eval board.
Yes we are using hello world template only
Can you please check this , because we need to inform customer regarding this.
i have attached the project archive with this . please let me know if any
Contributor
Please give response for this, our work is blocked with this
