FW_CODE_NOT_WORKING_WHEN_CONFIGURED_FPGA_WITH_JIC_PROGRAMMING
We have tried as per the steps you have mentioned in previous response. But relative address is not reflecting in the jic file generation.
reset vector offset is changed in nios ii parameter settings ,
hex data parameter is
we have tried with this , but firmware part is not working. Can you please guide us to resolve this as we have less time to give commitment to customer.
You need to create a new BSP and project in Nios II SBT, with the new .sopcinfo which has the address set.
- SERMASWATHIKA2 years ago
Contributor
i have created new bsp and generated hex file. with that also address is not reflecting..
- EBERLAZARE_I_Intel2 years ago
Which Quartus version are you using? Is the Cyclone V GT custom or the dev kit version?
Can you archive the Quartus design to me here? You are using the Hello World template in the Nios II SBT right?
I will help you check and create the .jic on my side.
Contributor
We are using 22.1 quartus version and currently we are checking the design in starter vino kit eval board.
Yes we are using hello world template only
Can you please check this , because we need to inform customer regarding this.
i have attached the project archive with this . please let me know if any
