OlegT's avatar
OlegT
5 years ago
Cyclone 10 GX FPGA Development Kit - PCIe AvalonMM-DMA example
Hello. I use AN829 as starting point of my design. In Platform Builder I see, that PCIe hip is connected to DDR3 emif via avalon MM bus. Both components use different clock sources, but they ar...
  • Hi Oleg,
    Thanks for your patience while I was checking the design.
    If you refer to the Platform Designer: Interconnect Requirements, there are some settings that allow the software to automatically insert the clock crossing adapters and add pipeline stages to the Platform Designer interconnect when you generate a system.
    In our case, the clock crossing adapter type is set to FIFO and maximum pipeline stages is set to 4.
    KhaiY
